Guest chrisll
I have haynes manual, but it didn't specify that. Can some one help me ?
Thanks.
-Chris
Thanks.
-Chris
The floor jack points are right next to the existing pickup points (notched section in the seam under the car). Have to be alittle careful - have to butt right next to the seam - if you go too far over, you will jackup on sheetmetal. If you don't use an adapter to slip over the seam - you'll crush or bend it. Depends on what kind of lift you have.
if it is anything like mine, you will find the front and rear suspension subframes have a little bump about the centre line of the car; these are the points i use.
