Guest The Dom
If some remember I had a problem with front and rear noise.
Found out today rear end the wheel bearings are shot.
How hard are they to replace?
Also Front end the noise is from the right steering rack.
Again how hard are they to replace?
Also its an '89 corolla seca 4AGE. I have had a problem with the A/C running the car stalls when the car is allowed to drop back with no accelerator from about 3000rpm. EG. coasting out of gear up to a set of lights. What could cause this??
My brother thinks it could be the piping from the air filter box to the throttle body. It appears to be taped and could be leaking. Would this produce a problem with idle speed and coping with the added load of A/C??
Thanks for your help.
