Guest Phuncz
Hello, I'm from Belgium and I ordered my new Corolla 2007/2008 model a month ago. Now that I'm reading a lot about it online, I discovered that the Japanese version has a lot more nifty gadgets than the European one. For instance, in Japan the navigation unit has a 30GB HDD drive for MP3's. Also, they are fitted with a rear-view camera as standard ! They also have the option to start the car remotely !! These things, which I really would like to have, don't come as an option here in Europe. So what I need to figure out is if it is possible for instance to add a 30GB (or larger) drive to the Sat Nav, what other parts might be needed and if the software will go with it. The rear-view camera shouldn't be a problem, but then again the question arises: does the Sat Nav have the nescessary connection for it ? Here in Europe, the Sat Nav unit is called the TNS700. It's a touchscreen Full Map Europe Navigation Unit, that can play MP3 CD's, has Bluetooth and can be hooked up with an optional iPod adapter that I have yet to see work correctly on the Sat Nav.
Does anyone know more about this or a place that I might look for this information ? Thanks in advance !!
