Every item that uses electricity is run by your alternator. Your alterator is powered by your engine. So the more watts you are drawing, the more resistance your alternator is putting up. DRL draw a a pretty decent amount of electricty and they are on ALL the time...so they are a slow and steady drain on your MPG. Not much, but a lot of small changes make a big change.
Increased speed increases wind resistance, and lowers fuel economy. Even a slim Corolla goes from being a slick dart to a big fat brick once you start going fast enough.
I found this graph showing how increase speed has a lot of effects on MPG. I admit, I drive fast on wide open highways when I can, but I try to keep it below 70, and around 60 under ideal conditions.
http://www.trucktires.com/us_eng/library/p.../fuelecon/2.asp
Not hard and fast but it gives an idea.
But, I think that driving habits are the biggest factor. I could be wrong but it is what seems to distinguish those who get 40+ mpg and those who get 30+ mpg. Next time you get an itchy foot and want to pass those two or three cars, make a mental note of them and then pass them. Probably, you'll see one or two behind you at the next stop sign, traffic light or toll booth. But, they won't have spent that extra gas. I noticed this when driving on 90 around Albany, some people drive crazy through traffic, but then I end up right behind them in the toll booth...what did they gain for driving like demons possesed them? About five seconds I guess
G
