Well, let's say that I play with stuff that has something to do with stuff or does stuff above, at, and underwater for my job. "Fish" in the water means something a little different to me
Yeah, take it back and have them redo the balancing. Before you do - take note on how much weight there already is on the tire and wheel. A good tech should put the least amount of weight possible to balance a tire. Should be around 2oz total weight or less. If it takes more weight to balance, then you either have it on the machine wrong or the wheel is a goner. Could have been something as simple as a weight weight falling off or they didn't have the wheel mounted correctly on the machine. I usually balance my wheels twice - first go around to get the balance, take the wheel off the machine, throw it back on and redo the balance. If I did it right, balance should come up zero - otherwise, I know I screwed up or need to redo it again. Takes only a few extra minutes, tops - as the process is pretty automated. Some systems will even stick the weights on the wheel for you.
Most places do not have a written alignment warranty that I know off, unless it is part of a contract or package deal - as you could roll of the premise and immediately hit a curb. But many places will recheck the alignment for free, if you bring it right back to them with a problem. Every place I've taken my cars for alignment have missed one every once and a while - even when I do the alignment myself .
