That sucks - they don't come in a 185/65R14? Oh well.
Fortunately, a 195mm width tire will fit a 5.5" wheel width (5" to 6.5" range).
Unfortunately, the tire diameter is off by a good sized percentage.
Over 5% bigger then the OEM tires. What that means is that your speedometer will display 65MPH "indicated" while you are actually moving at more than 70MPH "ground speed".
Would have to go PLUS 1 (195/55R15) or PLUS 2 (205/45R16). I checked Tirerack and they don't carry the PLUS sized ones either. You would have to reflash the ECU to accommodate the larger tire size.
