I own a 2000 Corolla CE with a/t (4sp) and it has almost 129,000 mile on it.
I recently had the dealer flush the fuel injection and clean the MAF sensor due to hesitation off idle in the morning. It no longer hesitates:)
I just changed the spark plugs and cleaned the OEM PCV valve. Other than checking the valve clearance (I plan to do this in the Spring) what should I clean/check for the sake of MPG??
Btw, I also have had the a/t flushed on schedule as well as the coolant.
Also, I want to change the fuel filter and pre-filter screen in the gas tank but it is not clear how to remove the access cover to the fuel pump under the rear seat?? There is a small rubber cover the pump wire goes through and that engages in the larger oval access cover to the pump. This oval access cover seems to be made out of thin guage metal and it seems to be welded to the car?? The Toyota factory manual says to remove this access cover and then remove the fuel pump. How do you remove the access cover??
