DaRi_GJ
Hi all, this is my first time posting, I find this forum really helpful.
I have a 2002 corolla CE, I bought it about a month ago from another person.
It had a P1656 code -OCV circuit malfunction (bank 1)- (My bad for buying it like that) I took it to an independent technician. (Changed air filter, fixed air intake leak, fixed an air filter box crack, supposedly connected a loose wire) and the code was gone.
Minutes after I drove it the light came on with the P0420. Tried to check the cat converter but there was no cat converter!!! They erased the code, but it came back after a couple of hours.
I searched for cat converters on the web, I found some for about $200 (Direct fit) and other for about $60 (Universal) – 1st question: what’s the difference? Quality? Cons?
I also searched for O2 sensors since I don’t know if they are good, and I found (1, 2, 3 and 4 wires sensors) – 2nd question: why is that??? which one am I supposed to use? Isn’t it standard? (sorry if I’m being ignorant)
3rd - Besides polluting the environment and having a very poor mileage (18 mpg!!!!!), what else can happen for not having the cat converter? (emission tests are not required in my country)- the poor mileage should have other causes, I'm working on that, but that's gonna be another post.
4th – I’m not using leaded fuel, and I’ll check the O2 sensors/ spark plugs/cleaned de MAF sensor (I learned how to do it by reading your posts ). What else am I supposed to check before installing a new cat converter so it doesn’t get killed again? Consider my knowledge about cars is really limited.
Extremely long post, but thank your very much for your help!
