would it be feasible to install an audio in jack on the radio, (for mp3 players, etc) or would this result in more interference or other problems than benefits?
2004
thanks
by induction1, September 3, 2004
2004
thanks
I think I read about this somewhere...the CD changer controls are available but unused in most Corollas...if you have a stock headunit with no CD changer, then you can find the harness and it has a couple pins, some of which are audio in. You then use the CD button to switch input sources..
I just read about this, but I can't remember where...if I do find it, I'll post back here.
As far as problems, I can't envision any. Just make sure you have the volume turned down when you insert and remove the audio plugs.
G
