the 03 corolla's have 5x100 lug pattern, but i am not sure of the offset and stuff, but the 02+ WRX stock rims are also 5x100 lug pattern, does anyone know if those rims would fit the corolla? they are 16" rims, and usually the WRX guys would ditch them for aftermarket rims, so it usually means cheap on the local classified,
As long as the backspacing is the same - should be OK to run WRX wheels. As far as I know - the WRX uses a 48mm to 52mm backspace - where the Corollas usually run about 10mm less. Get the incorrect backspacing and you will have clearance problems.
you mean the wheel offset? yeah, i was wondering what is the offset for corolla?
Yup - IIRC - you can run wheel offsets from 38mm-45mm for a Corolla. Most of the WRXs are deeper - 48mm and up.
