At 7500 I intend to roate the tires (front to back - same side) and another oil change.
At 15,000 I'm going to do the same as above plus drain and refill the auto tranny fluid with a pan drop and filter change. Also air filter change.
I'll wait till 30k to drain and refill the coolant. no flush.
I've heard a few complaints about the corolla door seals. Here's a solution I used when I lived in the desert 115 degree dry heat which is particularly hard on door seals:
Rub a little Armoral on the seals once a month. It will keep them conditioned, flexible, and in perfect condition. It takes 4 minutes to do the whole car.
