Here's the deal - With gas prices as high as they are these days, have you ever dreamed of a gas tank that never empties? Well, I have one (sort of).....
My 1999 LE gas gage is stuck on full. It won't budge. I almost ran out of gas, not paying attention, until the low fuel indicator light came on. I thought "how can I almost be out of gas, when the gage reads full?"
I did some reading - some say it's the gage itself - something about variable resistance - the emptier the tank gets, the lower the resistance, and the lower the gage needle reads. Conversely, the fuller the tank, the higher the resistance, the higher the needle reads. I have no idea how to measure the resistance going to the gage from the sending unit.
Others say it's the sending unit, which is attached to the fuel pump, located inside the gas tank, under the back seat.
Well, I took out the back seat, located the access panel for the fuel pump. There's wires. No obvious signs like loose wires, corrosion, etc.
Now what? How do I check whether it's the gage, or the sending unit? Each one sells for about $125.00 - I would hate to pick the wrong one, and end up in the hole any deeper.
Any help would be greatly appreciated.
KMC
