Hello All,
The best information I ever got regarding mirrors was given to me by a police driving instructor. He said, "If your mirrors are properly adjusted, you won't have any blind spots." Turns out that he was right. Try this...
1) Set up your seat in a position of comfort for you.
2) Adjust your rear-view mirror so that it gives you a clear view out the back window when your head is in the position that it normally is while driving (ie. not leaning back against the headrest...unless you actually drive with your head there)
3) Turn/tilt your head to the left as far as you comfortably can without turning your shoulders (in the 10 o'clock direction). With your head in this position, adjust your drivers side mirror so that you can see only a couple inches of the drivers side edge of the car in the mirror.
4) Turn/tilt your head to the right as far as you comfortably can without turning your shoulders (in the 2 o'clock direction). With your head in this position, adjust your passenger side mirror so that you can only see a couple inches of the passenger side edge of the car in the mirror.
5) Return you head to a neutral position. You should now have a clear view of the what is behind your car through the rear-view mirror and clear views of what is beside your car in the side view mirrors. If this is done properly, you will NOT be able to see any of your car in your side view mirrors.
6) Head out on a multilane highway. pass cars and let cars pass you. When cars come to pass you from behind, you should see them in your rear-view. Before they disappear out of the rear-view, you should see them in your side-view. Before they disappear out of the side view, you should see them in your peripheral vision. You will always see them in one of these places, so you will have no blind spots.
When you pass cars, it's just the same, but with the steps reversed.
It's still a good idea to do a shoulder "peek" (as opposed to a full shoulder check, which you no longer need to do) in order to pick up very tiny things in the city like joggers, bicycle couriers, skateboarders, etc. The way that my mirrors are set up, something has to be smaller than a bicycle to escape my view.
As a disclaimer, this technique, like all driving techniques, is only as effective as the driver. If you're a crappy driver, this won't make you a good driver. It may make you a slightly less crappy driver. Also, I've been told that it may take some getting used to. That was not the case for me, but I'm just pAssing that on. One more thing...effectiveness may vary from car to car based on design. It works fine on every car/truck I've tried it on so far, but I haven't tried it on everything.
Good luck and have a safe drive.
Regular Joe
ps. If you need to use your mirrors to see edge of your car and the curb when parallel parking, just turn/tilt your head.
