Hi! Just got a 06 Corolla LE (Canada) and finished reading the manual, found a few "interesting" things:
1. In the Automatic Tranmission section, they mention no to put your foot on the accelator pedal while shifting, does it mean that I have to shift like a manual (lift off the gas and depress the clutch)? interesting...
- That is weird, never heard of a automatic that needs you to take your foot off the gas pedal before shifts. I do it sometimes out of habit (especially from jumping out the manual transmissioned car into the automatic one) and it "seems" to upshift quicker, because there is less of an engine load on there.
2. In the same section, they suggest using "D" even for hill-climbing. I tried it on a hill with varied slope, the "grade logic control" (sorry, it is a Honda term, what is the term for Toyota?) of the AT is not that "smart". I would prefer shifting to "2" to avoid the AT shifting to "3rd" on the hill. I don't like climbing the hill with only ~2000rpm. That might save gas but I think that's not good for engine (correct me if I am wrong). But now, I have to lift off from the gas pedal and shift and depress it again. Mmmm.... Also, they did not mention going downhill with lower gear...
- Many automatics will suggest to leave it in drive (D) even on the hill - prevents overheating of the transmission fluid from driving under a load up a hill. The transmission will downshift to keep the revs up. True, it is not good idea to "lug" the engine at low speeds with a heavier load, but at ~2K the engine is far from lugging. Same goes for downhill. Only time I will select a lower gear is if I have a much heavier load behind me or in the car (ie. trailer tower) - otherwise, I leave it in D.
3. The "2" is not a real "2nd" gear since when you start the car with "2", the AT will start at "1" (which is a real "1st" gear) and then shift to "2nd" automatically. But the manual does not mention "automatically shifting to 1st when slowing down with the 2". On some other ATs, the "2" is a real "2nd" gear.
- Just the design and programming of the transmission - some will ONLY select the indicated gear. Many automatic transmissions will start off in a lower gear and upshift to your desired gear. Basically it tells the transmission what the "highest" gear it is allowed to use. Some transmissions use adaptive shift strategy (downshifts as you slow, holds a gear in cornering, etc.) - the Corolla is in that league yet.
4. I think the AT shifter is a electronic switch since the manual mentions when shifting from "D" to "2", the AT will downshift "WHEN" the car speed drops down to or below 105km/h.
- Most automatic transmission will do this - keeps you from overreving the engine. Though some transmission will try to shift to that gear, even though your speed it too high (ie. manual valve bodies, sport programming, etc.)
5. The maintenance schedule shows oil change is every 6 months/8000km. Isn't it a bit too long? especially for the first oil change after engine break-in? Anyone know which manufacturer makes Toyota synthetic oil?
Thanks for any input...
- The maintenance schedule is designed as a guide for proper maintenace of the vehicle if driven in typical situations. With the quality of engines oils continuing to improve - 6K OCI on conventional motor oil, with the correct API, is no problem. Synthetics generally will allow you to run longer change intervals (depends on the make of the oil, some you should not use for extended oil changes) - last I heard, Toyota OEM synthetic was made by Mobil or Havoline. If you are not happy with the interval - there is nothing in there that prevents you from shortening the oil changes. Plus with driving these days, I would stick with something between Toyota Special operating conditions (still 3K miles I believe) and their "typical" conditions at 6K miles ol changes (I usually follow ~5K with conventional oil, ~7K+ with synthetics).
Oh - Congratulations on your purchase and to hopefully to many, many miles of trouble-free service.
