Guest Markle
I purchased a used Toyota certified 2000 Corolla CE with 44,000 miles 3 weeks ago. It is making a pinging noise when I accelarate between 25 to 45 miles an hour when the engine is warm(makes the most noise when tac says 2000). The head of the used car department said it was probably an oxygen sensor and that they'd fix the problem. I've had the vehicle in each Saturday with them checking the noise. The head of the service department said the techs cannot find any problem.
IT RUNS WITHOUT PINGING WHEN IT IS COLD. Great sounding car if it never warmed up. After driving about 3 or 4 miles, when it gets warmed up, is when it starts pinging.
They said maybe the previous owner only did in town, stop and go driving. So I've taken it out on the highway(65/70 mph) for 700 miles and put premium (octane 93) through it. Now they want me to switch back to regular(octane 87) and run another tank of gas through it(150 miles so far). If that doesn't help they are saying fill it up again and add a bottle of injector cleaner. I feel like I'm the only person out here purposely running gas through my car, when everyone else is trying to conserve gas because of the higher prices.
That did not change anything. Now they are saying all 2000 Corollas have a ping. That doesn't sound reasonable to me. Any one with a 2000 Corolla CE, does your car have a ping or as the service tech called it, an octane knock? If it does or did, were you able to fix it?
The check engine light has been on 3 times. Told me it was evap codes. First time they ran diagnostics on it they said it was probably a lose gas cap. They turned off the light, I drove home, and the next day when I started it, the check engine light came on again. I had seen a discussion about evap codes and going to Autozone to have them check the codes. It was P0440, P0441, and P0446(2 times). Took it back to Toyota again, they ran diagnostics again. They have ordered a charcoal cylinder(cannister), supposed to put it on next Saturday. Not sure why they didn't see that the first time, instead of suggesting a lose gas cap.
So they've run diagnostics on it a couple of times, and turned off the check engine light. Is there some other kind of diagnostics that maybe they haven't done??? Any chance putting on the charcoal cylinder will fix some leak that is causing the pinging?
