Guest davect
Now that I've got the fuel injector problem taken care of, there is another problem that has been plaguing me for years with this car ('99 LE). I have a vibration in the front end at about 50-65mph that the dealer cannot find the cause of. When this first began I thought it might be the tires. Nope! I'm on my third set of tires and the problem persists. No sign of unusual tire wear. I always make sure they're rotated, balanced, and properly inflated. I've also had four alignments. Interestingly, the problem goes away whenever the tires are removed (to be rotated, brake repair, etc.) and then returns in a few days. Case in point: I just replaced the tires and the vibration went away. It slowly returned about 5 days later. Any thoughts on this? Wheel bearing perhaps?
