Havent posted anything in a while now. Its good to be back.My ECL has been on eversince I bought my corolla, and I knew I had P0125 and P0420, but I just kept driving because there were no pressing drivability issues. Then yesterday just to satisfy my curiosity, I hooked up my obdII scanner to find out what more may have gone wrong. Now I have a bunch of trouble codes:
P0125
P0420
P0440
P0441
P0446
I am not in a position to fix anything due to financially circumstances and even if I want I wouldnt want to do it, because my car is due for a complete engine overhaul before December this year. Besides the car has been driving okay (apart from its monstrous hunger for oil).
I would like to find out if I could keep driving without fixing any of these codes, or if there is chance of a major breakdown if I dont fix something immediately (which I cannot).
Those codes have more to do with emissions than anything else:
P0125 - Insufficient Coolant Temperature For Closed Loop Fuel Control
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0440 - Evaporative Emission Control System Malfunction
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P0446 - Evaporative Emission Control System Vent Control Circuit Malfunction
The only one that concerns me is the first code - P0125 - probably has something to do with the ECT sensor or thermostat sticking. If that doesn't get the ECM to think that the car is fully warmed up - you will be using up more gas and possibly seeing more oil consumption (fuel dilution) because of it. This is generally related to the P0420 code as well - as the coolant temp sensor is a major cause of this particular code (makes the ECM think the cat is not doing its job). Running around with this code constantly popping up would not be a good thing - I'd try and get this fixed as funds come available.
The EVAP codes are more a nuisance than anything else - I get those atleast once a year, usually right before emissions testing. You can still drive the car around - but you may notice fuel odor right after filling up the tank or right after you shut the car off. Most of them are related to various valves, solenoids, vacuum hoses, etc.
