Guest MarkD
Just bought a 2000 Chevy Prism a few months ago. It had about 50,000 miles on it and it now has just over 52,000 miles. We recently took about a 750 mile trip and burned some oil. I noticed black residue on the back bumper from the exhaust and then our check oil light went on. When I bought the car our mechanic didn't see any leaks, and I haven't noticed any either, so I don't think we're leaking anything. So when my check oil light came on, I added about 1.5 quarts to get the oil to show on the dipstick. Then I brought the car to an oil change shop - the guy noticed residue in the exhaust - so again, it is burning oil. Last night my neighbor and I looked at the spark plugs and they all had white on them. We also checked the pressure of each piston and they were all about 150 (psi?). Also, when I first got the car the "check engine" light was on - I went to autozone and the computer indicated it was misfiring and the guy recommended I change the plugs. But based on research, it seems the check engine light can come from a variety of sources, so I went with the unhook the battery to turn it off trick. It came back on when the "check oil" light came on, and went off after I had the oil changed. Since we checked the plugs, the check engine light is back on! I'm monitoring the oil regularly now and it doesn't appear to have lost anything since the oil was changed a few days ago. I'd imagine I just need to be paitent and monitor the oil for a few thousand miles to see how it goes. But thought I'd run this past you all to see what your impression was of the combination of 1) some oil burning, 2) white on the spark plugs, 3) piston "pressure" appears to be ok, and 4) check engine light. Would changing the plugs help? Sorry about the long, random description and thanks for any input!
