Put the new resistor in today. Success! The fan works at all speeds now. As far as getting the part like I said the Toyota dealer had a note in their system that the toyoto resisor pack does not work in the Prizm. This is a big dealership with a Chevy store also. I just walked to the chevy store. They ahd the part and it sounded like this is a common part to fail.
The resistor apck itself is a plastic connector with two nuts holding it to the blower. It has a cable harness connnected to it.
The plastic connector has a circuit board about one and a half inches square. There was no need to test it. The traces on the circuit board were noticably burned. The new pack had a slightlty longer board and looked built a bit better.
The hardest part of the job was finding a socket to fit the nuts on the connector. I ended up with a 5.5mm socket. Never knew thewre was such a thing. I think 5.5mm and 7/32 is close enough to work.
Thanks again everyone for the help!
