QuestionHow many engine mounts on a 1.6 L 1997 Engine?
What are the locations?
How can you physically tell they are worn.
I only found two on my engine and I could not tell if they were worn or not, but I surely have engine vibration at idle
I used to think there were only two, but after taking out an engine I can see there are four.
There is one (when you ar at the front of the car looking into the engine compartment) on the left which holds your air conditioning hose and holds up the left side - the side with the belts, one in the front just behind the radiator, one on the right which actually holds up the transmission, and one in the back that is holding up the transmission (transaxle - differential). That makes four.
You can tell that they are worn by checking the condition of the rubber. If they are worn too much the engine (and transmission, transaxle) will vibrate a lot.
My Haynes says that engine mounts seldom require attention, but broken or deteriorated mounts should be replaced immediately or the added strain placed on the driveline components may cause damage or wear.
The check requires lifting (the book says jacking) the engine enough to take the strain off the mounts. You check to see if the rubber is cracked, hardened or separated from the metal plates. Sometimes the rubber splits right down the center. There is more about making sure they are mounted tight and then a section on how to replace them. Hope this helps.
