Hello all, I'm a new Corolla owner.
I recently bought my 54,000 mile, manual transmission 2001 CE Corolla. It's a great car, but I'm afraid there may be something wrong with the transmission. I don't know the car's service or usage history because I bought it from someone who in turn bought it from a repossessed vehicle auction.
Shifting from 3rd to 4th gear while the car is cold lags, and sometimes altogether fails:
I depress the clutch pedal, move the stick from 3rd to 4th, lightly depress the accelerator, remove my foot from the clutch, and the car slows down considerably. Depressing the accelerator does nothing (no change in RPM, no speed increase) until the gear "catches" at which point I'm travelling at a slower speed and need to downshift anyway. This problem sometimes manifests itself between 1st and 2nd and 2nd and 3rd, which is very dangerous. Earlier today I was almost sideswiped making a left turn on a busy street.
Like I said, I don't know the service or usage history. I also don't know much about maintaining cars. What are the first things I should check? Where would you get it repaired? Could this be a transmission fluid problem? Would that mean I'd need a transmission flush? How much would that cost?
Basically, how can I make sure the local Firestone doesn't recognize I don't know my stuff and fleece me?
Thanks a lot for any feedback,
John
1. poor shift quality is caused when the fluid is thick because its cold, its a fact of life, but try changing the fluid.
2. it sounds like your clutch is slipping some, check the hydrolic system for air 1st and then check into the disc/flywheel/pressure plate.
If it is actually the transmission it could be due to fluid problems. I suggest you do a quick check of the quantity and quality of your transmission fluid.
It could also be related to your engine and not your transmission - it just may occur during the times that you shift.
Further investigation into the symptoms and also the exact car responses might help to better determine possible causes.
1. poor shift quality is caused when the fluid is thick because its cold, its a fact of life, but try changing the fluid.2. it sounds like your clutch is slipping some, check the hydrolic system for air 1st and then check into the disc/flywheel/pressure plate.
Hey, thanks for the input. Are these things the enthusiastic newbie can do by himself without any risk of damaging the car or his person? Is there any sort of reference I can check to find out how the hell to do these things?
I hate seeing things like "change the transmission fluid" and "check your clutch plate" because I know jack about cars. I want to learn so I'm not at the mercy of dealership service centers and dodgy mechanics, but I don't know where to start.
Anyway, what you're saying I should do is:
1.) Change the transmission fluid
If that doesn't fix it,
2.) Check the hydraulic system (which one? the clutch or the brakes or the transmission...? does the Corolla use a "hydraulic clutch" instead of a "cable clutch" ?)
3.) If there's an air leak in the hydraulic system, fix it by... changing the fluid?
4.) take the car into a shop to have them take apart the clutch and probably replace it, at ~$800 for parts and labor
Is that about right? I appreciate your responding, I'm just frustrated that I'm a car-idiot.
If it is actually the transmission it could be due to fluid problems. I suggest you do a quick check of the quantity and quality of your transmission fluid. It could also be related to your engine and not your transmission - it just may occur during the times that you shift.
Before posting here, I did some websearching and found a few resources about evaluating used car transmissions before making a purchase. The few suggestions I found were:
1.) Pull the parking break, put shifter in neutral, start the car; listen for noises; press the gas until the RPM's are at about 3-4k; listen for noises
2.) Start the car. Instead of starting out of 1st gear, start out of 3rd gear. If the car doesn't stall and starts going, you've probably got a bad clutch.
3.) "Test drive" the car. Make sure that accelerating immediately after shifting is smooth. If the RPM surges but you don't accelerate, you've got a bad clutch.
I tried 1, no weird noises. I was afraid to try 2. My results for 3 were a little odd: immediately after I shift and accelerate in the new gear, my RPM's don't surge. Instead, the car slows down, doesn't respond to acceleration until a second later when the gear seems to engage.
Do you have any tests I can do myself to further diagnose the problem? Is there an easy way for me to change the transmission fluid on my own? Thanks for helping out.
Your Corolla has a hydraulic clutch actuation system. When you depress the clutch pedal, you are pressurizing a master cylinder which transfers hydraulic fluid under pressure to a slave cylinder which actuates the clutch pressure plate fork. When the pedal is depressed, the fork is out and the clutch is disengaged; as the pedal is released, the fork is also released and the pressure plate puts the clutch disk in contact with the flywheel, increasing the friction (clutch "slippage" enough to get the car moving in low gear and then ultimately making full (non-slipping) contact with the flywheel at the point of full clutch release.
You have two possible problems:
1. The fluid in this system is somehow too thick to work in a normally responsive manner.
2. There is excessive wear on your clutch disk itself, it is not making good contact with the flywheel and is slipping badly. A classic symptom of a worn-out clutch.
I think you have no choice but to take your Corolla to a qualified mechanic to diagnose and do necessary repairs. Make sure he is familiar with Corollas and uses nothing but genuine Toyota parts.
Also, if this is such a big problem at only 54,000 miles, it definitely indicates that the car was either poorly maintained or deliberately abused by the first owner. Sorry.
Your Corolla has a hydraulic clutch actuation system. When you depress the clutch pedal, you are pressurizing a master cylinder which transfers hydraulic fluid under pressure to a slave cylinder which actuates the clutch pressure plate fork. When the pedal is depressed, the fork is out and the clutch is disengaged; as the pedal is released, the fork is also released and the pressure plate puts the clutch disk in contact with the flywheel, increasing the friction (clutch "slippage" enough to get the car moving in low gear and then ultimately making full (non-slipping) contact with the flywheel at the point of full clutch release. You have two possible problems:
I may be one of those people who doesn't use the manual transmission properly, and I agree that it's likely that the previous owner drove the same way or worse than I do myself (pressing the gas too much with the clutch depressed).
Is replacing the fluid in the hydraulic clutch system the same as replacing the transmission fluid that Bikeman said was quite simple? IE is it something I can buy at Walmart and put in my car myself? If I can't, how much do you guys think it should cost to get it diagnosed/replaced?
I've noticed that when I depress the clutch, I feel a strange, faint spinning sensation with my foot. Could that be the flywheel slipping, or is it nowhere near the pedal itself? Other symptoms of a slipping clutch don't seem to be present, though. The RPM's don't increase significantly when I depress the clutch, and they don't increase without a corresponding increase in speed after I shift gears.
And finally, if the clutch does need replacement =\, how much do you think it should cost? Where would you personally go to have it fixed? Is this the type of part that you can pick up at a salvage yard, or do you have to buy it new?
Thanks a lot for helping me out with this stuff--I already feel like I'm better equipped to handle the guys at the dealership. BTW, is there a particular repair manual you would recommend for a newbie?
