Guest Rolla96
sup guyz, i got a 96 corolla 1.6L ... its a 11 Gallon tank im gettin 230 to a full tank... dats pretty bad... ne suggestionz on wat the porblem is?? thanks
Could be almost anything. Rolla with the 3-speed auto / 4-speed auto / 5-speed manual? How many miles?
Check the usual stuff first:
-Need tune up? May need to replace plugs / wires / distributor / etc.
-Check tire pressure
-Check alignment
-Check air cleaner
-Check fuel filter
-Check TB, may need to clean
-Check O2 sensor
-Check PCV
-Check for good chAssis ground
-Check brakes, may be a sticking caliper
-Check transmission, for slipping, etc.
That is a good start - after that - have to look more closely at the internals / driving conditions / fuel delivery / ignition issues.
Good Luck.
