Guys, could anyone tell me where the fuel filter is located on the 2000 Corolla, and if it needs to be changed periodically.
Thanks.
by Braddale, October 13, 2005
Thanks.
now_driving_VW
should be in the engine bay...on the driver's side. It's a black metal cylinder with 2 hard fuel lines going in and out. Toyota claims it's lifetime... but yes, it needs to be changed every once in a while... every 60,000 should be more than sufficient.
The tricky thing is the banjo bolts. They are extremely tight, and easily stripped (use a flare nut wrench)
I believe it is only in the engine bay on previous generations - it was nice because you can get to it easily.
The 8th generation Corollas and newer (1998+) have the fuel filter inside the tank. Only way to it is to remove the lower rear seat cushion and unscrew an access panel above the tank.
Normally - you really don't have to worry about replacing the filter element unless you know that a significant amount of debris got into the tank somehow.
Bad_dude
I believe it is only in the engine bay on previous generations - it was nice because you can get to it easily.The 8th generation Corollas and newer (1998+) have the fuel filter inside the tank. Only way to it is to remove the lower rear seat cushion and unscrew an access panel above the tank.
I think the 98 and newer models, the fuel filter is in the pump.
Max
As Fish noted,on 98+ Corollas, it's in the tank.
