My 2004 Corolla now has 28,000 miles on it. I change the oil every 3k and the air filter every 15k and rotate the tires every 7.5k. That's all the maintenance I plan to ever do on this car and I expect to drive it for 150k without a glitch. I think my chances of accomplishing this are very good.
My question is this - should I really drain, refill, and/or drop and clean the tranny pan at 30k. Is this really necessary? Who cares if there are metal shavings stuck to a magnet in the pan? If the tranny fluid is red and smells good - then doesn't the old saying kick in, "If it ain't broke, don't fix it". Keep in mind, the tranny fluid in my car is only 18 months old.
Isn't a transmission like an expensive watch. You open it up unneccessarily and the air/dust that gets in does more harm than the good created by the maintenance attempt.
Just some thoughts.
