Guest nregi
Hello,
I need to remove the door panel on driver side for 2000 Corolla LE?
I got the bottom tabs off and took off 2 screws inside the top handle cover.
I don't now how to proceed further?
Thanks.
Hello,
Thanks.
Got to get door handle off as well - should be a screw in the trim around the handle. Swing it out a ways and disconnect the pin inside. The door panel should be able to be pulled out and then up to lift it off the door frame.
