Guest Mikeyworks
Greetings,
I am posting for a friend. He as an '01 Carolla S with the 16V VVT-i engine (I think) and it's showing signs of severely decreased performance. It has about 66K miles on it, but other than that, it's in great shape.
Symptoms:
1) While running, but cold engine, it hesitates to an almost stall before the engine engages and you can drive away
2) Check engine light that comes right back even after disconnecting the neg (-) terminal on the battery
I checked the O2 sensor and it was a bit coked. I cleaned off the surface and used some electrical parts cleaner to clean the contacts/sensor in it.
I didn't seen any loose vacuum hoses or anything under the hood that would have given any clues.
I am thinking of limping it over to Autozone to have them get the trouble (CEL/MIL) codes off of it for me so we can see what's going on.
If it's the O2 sensor, Autozone lists one for about $100+, but is there a generic one I can use and just splice the connectors?
Thanks,
Mikey
