Guest Shift
I have a 2001 Corrla CE with 170K Km. On a cold start the engine idles good and accelerates OK the first time. If the car comes to a stop before the engine is fully warm the engine idle soemtimes drops very low and the car stalls. Usually the idle is OK but as soon as the gas peddle is pushed the car stalls. The car will accelerate instead of stalling if the gas peddle is lightly pumped while starting off. the problem has been getting progressively worse over the past 80K Km. The " Check Engine" light has never appeared.
I have discussed this problem with my Toyata dealer. The service people felt that the only possibility for a problem was that the mass air flow sensor was getting dirty and sending bad readings to the CPU. After a careful cleaning of the sensor I found that nothing had changed (the sensor looked very clean anyway).
Spark plugs, Air filter, PCV valve have all been changed.
Does anyone have any ideas as to the cause of this problem?
