I will need to get new tires for my 05 LE in about 9,000 miles and the stock Goodyears suck. I decided to start looking now...
I was thinking of changing to a wider tire width.
TRD sells a 225/40-18 tire/rim package, but 2Gs is a bit much and I don't need the bling. ( http://www.trdusa.com/SearchDatabaseResults_home.asp )
Givin the larger TRD tire/rim should fit, I thought to seek a 225mm tire. After visiting 1010tires.com's tire calculator I found 225/55-R15 would be the correct size for me.
The problem I found was the tire I wanted (BFgoodrich Traction T/A) does not come in that size...not many tires to!
So I found the 215/60R15 could work 'in theory'...
Does anyone have any thoughts or experience with fitting a different then stock tire size?
