smug
Shell Rotella T6 5W-40
Since new always used Moble 1 and did all oil/filter changes myself.  1ZZFE is a noisy thing.  Its noisy on start up and then when warm is quieter @115k miles.  Retired now no longer driving 10-12K miles yearly. More like stop n go around town...5K miles yearly.   Rotella might be better oil with the HD additives than Mobil 1 I've heard. Quieter, better stop n go protection.   Anyone using Rottela T6 ?  I think i give it try.  See if quieter.
I wouldn't use it... or additives. Just don't worry about the noise. If you're using synthetic oil and the correct grade (was it 5W30? I can't recall...) then you're set. Engines can last hundreds of thousands of miles in those conditions.
Agreed. I had a car whose engine made a valve-tap noise pretty consistently for around 100,000 miles. Then I sold it ;)
