elite engineer 0 Report post Posted February 11, 2014 I have a 2007 corolla..my compression ratio is 10:1..should I be using 89 octane instead of 87. When I use 87 oct, my car exhaust puts out a sulfur smell.. ~ee Quote Share this post Link to post Share on other sites
dom 0 Report post Posted February 11, 2014 I also dislike the exhaust smell and reduced performance and efficiency on 87 pump octane (91 RON) with 10% ethanol. I use 91 pump octane (95 RON) which is locally available ethanol free. http://pure-gas.org/ Quote Share this post Link to post Share on other sites
fishexpo101 13 Report post Posted February 11, 2014 87 octane is the minimum that you need to run on this car - with the better fuel and ignition control they have now - even 14:1 (Mazda's SKYACTIV-G) on regular pump gas is completely possible. That old school thinking of 10:1 as being high compression is no longer the case. Just pump in whatever seems to give you the best MPG to cost. Dom has a very valid point - pretty much all the regular gas you can find and many of the premiums have some percentage of ethanol mixed in. Generally 10% (E10 gas), some places in the midwest have E85 (85% ethanol). Though ethanol does burn clean, it is fairly corrosive to fuel system parts at higher concentrations, and you get less energy per unit volume - compared to gasoline. Sure it has a higher effective octane rating, but that doesn't offset the lower energy potential of the fuel. I personally like to run purse gasoline, if I can find it. Atleast 10-15% more MPG, emissions are just marginally higher, nothing compared to those older cars that don't fall under emissions checking. For me, I actually spend less money by using premium fuel over the OEM recommended regular. Even at the higher cost on the initial fill-up, I recoup that cost by able to drive further on that same volume of fuel. Each car is different - some have a markedly difference in MPG and performance with different grades of gas, some do not. On my 2009 RAV4 - makes almost no difference what I use to fill up, runs about the same. On my 2002 Corolla - I can easily see a definite 10-15% increase in MPG, just by running a higher octane fuel. Quote Share this post Link to post Share on other sites
