Eventful day! I got the front bumper strip and passenger side strip blacked out, looks real nice! I buffed the pass side down with some meg ultimate compound, I'll wax it in the morning and do the rear bumper strip tomorrow. Leaving the lower bumper trims gray since they get too much abuse, I doubt the Forever Black will stand up to it, it doesn't soak into these plastics as nice as it did my Celica side skirts.
I fixed the pass side door lock issues, there's a pivot that the lock actuator attaches to that translates it's motion up to the latch, the pivot had seized and the rod clip at the DLA popped loose. I set the pivot in front of the heat gun for a while and then gave it a few whacks with a little wrench while I held it with a vice grips, it came free and I flushed it with WD-40 while spinning it, once it was totally free I lubed with spray lithium, it should be fine for a while now. The door lock cylinder had some plastic debris inside jamming it, shook that out and purged the lock of debris with some mild solvents, flushed out a slurry of metal and old grease, lubed with spray lithium grease, works great now! The pass side is the only power lock, it just clones the actions of the driver side manual lock, cheesy but effective I guess.
I wiped the driver side mirror with the wrong rag and ruined the finish on it, acetone, whoops! So I pulled both and gave both some satin black paint, the pass side got some fish eyes for some reason annoyingly so I'll have to lightly sand it and re-coat tomorrow, how annoying. I prepped the d/s with the same cleaner but then hit it with some SEM plastic prep spray, that one came out perfect, lesson learned. Clean wasn't clean enough!
The pass side speaker is badly water stained and the cone is ripping/thin in spots so I ordered some replacements.
http://www.parts-express.com/kenwood-kfc-c1655s-sport-series-6-1-2-dual-cone-speaker-pair--267-4326but from Amazon with prime shipping and my rewards balance they cost $15 for the pair. They should sound as good as or a little better than the OEM speakers with the 16W RMS JVC CD player in the dash.
It'll be like getting a new car when she gets it back, just wish I could fix all the rust on it and take the slop out of the shifter, another time.
