I wanted to know what is the advantage or why is it better to use a bigger oil filter on your car.
By
Bull6791, October 30, 2014
If you plan on doing extended oil changes, then a larger filter with generally more filtering media, would be preferred. Filter will be able to hold onto more "stuff" before it gets loaded to the point of going full bypass. Otherwise, if you keep to a short of conservative oil change interval, it just more for owner preference.
