Don't need to do a VOA unless you want to find out what the additive package looks like or running something non-standard, ie. blending your own oil. Pennzoil Ultra should have a number of VOAs already available, like this one for a 5W20:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1778710
Notice how high the TAN number is - it is 13. Meaning lots of reserve alkalinity to fight off the normal acidification that occurs as a function of a working internal combustion engine. Also note the viscosity - right in the middle of its range. Those are some numbers you want to keep in mind during your testing phase. 65% point on TAN would be around 8.5, most oils will continue to protect down to about a TAN number of about 2 or 3. You can push it even further, but since you don't drive a lot of miles, would be best to stay above a 3 if possible. If you drive a lot, might get away with TBN as low as 2 or even 1. Blackstone considers TBN of 1 to be low - but if you look around, Dyson and members of BITOG consider that WAY TOO low for many drivers of mixed driving. You can also see if this oil tends to run thin or thick for your engine (look at the viscosities - higher numbers = thicker, lower numbers = thinner.
There will be some variances due to manufacturing tolerances, but should be all pretty close. Since a VOA has already been done - you can skip that part.
For comparison - here is a test on an Infiniti G37, 5000 mile run on Pennzoil Ultra 5w-30:
http://www.myg37.com/forums/engine-drivetrain-and-forced-induction/210156-oil-analysis-on-pennzoil-ultra.html
Note that the viscosity dropped out of grade, actually thinner than a 20 weight. TBN is a 2.7 - Blackstone estimates that the oil can be run out to 7500 before TBN drops to 1. That engine is known to be tough on oil - IMO, that oil is done at 5000 miles. Falling off of grade is one thing, but the drop of TBN from ~13 to less than 3, means the oil had to work really hard over that 5000 mile interval. This engine would be an example of a bad candidate for extreme extended oil changes.
