Hi,
I am in need of some guidance.
Story line will be a little long but please bear with me.
I have a 95 Corolla wagon 5spd manual transmission.
It has little over 375K miles.
It had developed somewhat of a knocking sound while engine is running in neutral, clutch engaged (pedal up).
When I disengage the clutch, noise goes away.
After googling around, I found this may be input shaft bearing in the transmission going bad.
I did not have any issues with the shifting gears nor with slipping clutch. They were all ok.
Car also had some oil leaks from I thought front crankshaft seal.
So I took it to mechanic I knew from past, about 150mi south of where live.
He listened to the sound and said it can be clutch or release bearing or something else in the transmission.
I repeatedly told them my symptoms and what I thought the culprit was from my research.
They came up with an estimate.
They wanted to replace clutch, release bearing and clutch master/slave cylinders on transmission side.
In front side of the engine, crankshaft seal, timing belt, waterpump, oil pan gasket and valve cover gasket.
I told them I did not need master/slave cylinders replaced and with that estimate total was about $1200.
They said, after taking it apart, if they see something else needs work they were to call me.
I OK'd it.
Couple of week later, last wednesday, got a call telling me car is ready to pickup.
I got there friday afternoon.
Went straight to the office and proceeded to pay the balance (stupid I know).
As I asked whether input shaft bearing got replaced, she said no.
I figured it didn't need replacement then.
Paid it and went to the car the guy who worked on it.
Propped the hood open, little plastic piece over the valve cover was missing.
Also realized, they did not replace the belts (alternator, a/c, waterpump etc).
I was pissed, but not ready for the final blow.
As I started the car, I noticed the knocking sound was still there.
I pulled the car up to bay they were working at and asked them about it.
Mechanic first tells me this is an old car and he didn't promise me a new one, all the while he's trying to rock the car back end forth to see if noise would be changing.
Told him this was the very same noise I got the car to them in the first place.
It was late Friday and he asked me to leave the car so they can take another look on Monday.
Actual owner calls me yesterday and tells me it will be another $450+parts for them to take the transmission to transmission place and have bearings replaced.
I tried and kept my cool but as he realized their boneheaded act, he got angry, blamed me for trying to get my "damn" car repaired for free.
He was going to pray to Jesus last night (no joke here) but I still did not hear back from him.
Mean time, I went ahead and canceled the card I used to pay for the repair.
I trusted this shop and I had worked with them in the past but knowing what I know now, I wouldn't have taken my car to these people.
Condition of my car is fair. Paint is faded. Have a dent in driver side rear door. Tint is all bubbled up. Still has the cracked exhaust manifold:)
Just a week before dropping it in the shop, I replaced the alternator.
Other than these, it has been rock solid. I wouldn't have hesitated to drive it cross country.
My question is, what would you do?
One option is to pay $1200 and get the car back with the knock (I had driven it with the noise ~20Kmiles past couple of years)
Second one is just leave the car there.
Third is buy a used transmission and have them to install it. For this I am looking at an additional $500.
I would very much like to hear your comments.
