Talking about something like this?
Yup, had one of those - threw it out the second or third time I used it. The drain cap on the side leaked almost immediately, which made the drain pan pretty much useless. The top part doesn't always want to screw down tightly, can leak as well. Makes trying to transport that to a fluid collection center pretty much impossible.
I ended up with two different ones. This one:
Similar to the square one (also made by Blitz or Rhino) - again same issue, the cap on the spout leaks pretty much immediately, the plastic tethering ring broke off quickly as well. I liked it better than the square one because the solid top made it easier to fish out little nuts and bolts. The mesh on the square one - they drop right in. The only issue is that center valve - if you don't pop it out correctly - oil will pool very quickly and overflow the side. Still - with the pour spout - I could eventually pour it into the old oil containers for disposal later.
My other pan - similar to the above design, just with an open top.
Simpler design - still, that oil spout cap had issues, but the open design means I can drain pretty much anything into it. Major drawbacks - anything that drops in has to be fished out later. Have to clean it after use, otherwise it would cause pretty strong oil change odors to get everywhere in the garage. Just have to watch how you pour it - as oil can slosh around pretty badly.
Was thinking about getting this one:
http://www.northerntool.com/shop/tools/product_200342358_200342358
But hard to justify the price and size. Might be good for multiple jobs, where I change all 3 or 4 cars oil at the same time. Good for some of my project cars that has an external oil sump (12 quarts) - but still, takes up a lot of real estate in the garage - just barely fits under the car. Also14.5 gallons of used motor oil will weight over 100lbs.
