Guest AtoB
Need some help...
1990 corolla sedan, 4-door, 3-speed auto...
I was going to replace my rear brake wheel cylinders today, but none of my wrenches fit onto the two 10mm bolts that hold the cylinders on. I tried open-end, box-end, and flare nut wrenches (Craftsman) but there wasn't enough clearance on the side of the bolt -- the part of the body of the brake cylinder that connects to the brake hose was in the way, so these wrenches wouldn't fit snuggly. My 10mm socket, 1/4" drive (Craftsman) fit nicely, but only without the ratchet attached. With the ratchet attached, the strut was in the way and I couldn't get the socket over the bolt.
My question is what kind of wrench can I find to fit correctly without risking stripping the bolts? Seems like a socket that is a little shorter than standard would do the trick, but what brand should I look for? I found online something called a "wrench socket" that seems like it would fit over the bolt and then can be turned with a regular wrench as one possibility. Not sure if I'm missing some obvious trick or obvious tool here.
If anyone has done this job before and can offer some advice I'd appreciate it -- thanks!
