Guest case310350
Looking for the psi of the low side AC system. my ac is weak pressure is at 30 psi which is enough for most cars, my manual does not give pressures. So would this be a weak compressor?
Low pressure side should range from 21 PSI - 36 PSI - you car sounds like it is in range. There a specific problem you are trying to diagnose?
