Here are some ideas that will help get the best gas mileage out of your car.
· Use synthetic motor oil. It helps reduce the drive train frictional losses and the amount of power consumed to push the oil through the engine. If your car uses SAE Grade 5w-30, use Castrol EDGE 5w-30. If your car uses SAE Grade 5w-20, use Pennzoil Platinum 5w-20. Both of these oils have very low kinematic viscosities for their respective SAE grades, which will help your engine deliver better MPG. Use the standard Toyota oil filter for your car. They have very low resistance to oil flow. Better oil flow yields better engine and MPG performance. Change the oil and filter at least every 6 months or 5000 miles.
· Pour a can of STP fuel injector cleaner in the gas tank every time your change the oil, this will help prevent the fuel injectors from becoming clogged.
· Make sure your tires are properly inflated, when they are cold, i.e. been sitting all night. A portable air pump helps accomplish this. Tires gain about 4 PSI as they warm up from driving, so it can throw off your pressure check and inflation efforts. Make sure you are using a high quality, accurate tire gauge as well. When replacing your tires be conscious of the weight of the different tire models. Avoid the heaviest tires, because they offer more inertia to overcome when accelerating.</SPAN>
· Use a cleanable / reusable Toyota TRD low restriction air filter and associated maintenance kit from the parts department at your Toyota Dealer. It will help increase the engine torque, allowing you to stay in a higher gear in any given situation and therefore get better mileage. Using it will not jeopardize your warranty. They are not cheap, but gasoline and disposable air filters are not cheap either. If your Toyota Dealer does not carry a cleanable / reusable low restriction air filter and associated maintenance kit for your model car, get one from K&N Filters through your local auto parts store. Clean and re-oil the filter at least twice per year, more if in a dusty environment.<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></SPAN>
· Wax the car and use Rainex on the outside of the windows every six months. This will help reduce the aerodynamic drag on the car, especially in cold weather when the air is denser.<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></SPAN>
· Make sure you are not carrying un-needed weight in the car, like heavy tool boxes or sport equipment, etc.</SPAN>
· Accelerate as gently as possible, especially prior to the engine warming up.
