Guest HPS-2001
I need to know how to reprogram my Toyota remote for a 1995 Corolla. I lost my manual. Thanks for any help you can provide.
By
Guest HPS-2001, September 24, 2007 in Pre-1997 Toyota Corolla and Geo Prizm
I am not sure, but I think you need the code and maybe only the dealer can do it??
Can anyone confirm this??
I know that you can reprogram remotes from 1998+ by yourself. Not sure if they had this functionality on earlier Corollas.
You can try this:
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. After 80 seconds new key is registered and security light goes off.
8. Remove new key and depress and release brake pedal 1 time.
There is also one where you short some diagnostic pins under the hood - and a similar open/close/key cycling to program a remote - but that has only been confirmed on Camrys, thus far.
For early 8th gen Corollas - may work for the 7th gen. Note - this is only for factory keyless extry systems, aftermarket - you are on your own. If this doesn't work - you may have to drop by a dealership to get the remote programmed.
