Most experts nowadays recommend against putting anything in front of the radiator. ANY kind of screen put in front of the radiator affects it's cooling efficiency even while it is clean, because at a minimum the screen slows down the air flowing through it. While it may keep bugs off for a while, it too can eventually gets plugged up and lead to overheating problems if not looked after closely. Newer cars have less of the radiator exposed than older cars do. This means there is less chance of them getting really plugged up, and also means that having a direct, uninterrupted flow of air to the part of the radiator that IS exposed is that much more critical. In new cars, air is very carefully channeled into the radiator, largely from under the car...and nothing should be done to disrupt this. If you have A/C then the condenser is already in front of the radiator, and putting anything else there can really cause trouble. If you notice that your radiator seems to have alot of bugs and stuff in it, then just spray it out from the backside (engine compartment side) until it is clean, or use a Shop-Vac and suck the stuff out. I have never heard of any rock damage to a radiator...maybe on '60's or '70's cars which had radiators that were more exposed. I don't think that it is a problem on newer, aerodynamically styled cars. Regards, Aaron
