I just thought I'd pass this along.
Just installed my old subs and amp in my corolla today, here are a few things I found out :
There is a very nice post for hooking up your power wire to under the cap. 10-12 gauge eye crimp fitting works perfect, but you have to notch the cap for the wire to exit. Boy was the nut on the post tight...
The firewall plug is doublesided. Take a nail and poke a hole and push your wire through until it stops. Go on the other side and look for the bulge. Poke a hole there too and push your wire through.
Be very careful routing the power wire from the firewall plug to the drivers side door trim. Many things for the wire to abraid/get pinched by. Use zip ties liberally!
The kick guards/door trim pop up. Start at one end and be firm. There are about two or three catches on each one. Best to pull on the side closest to the seats. There is a plastic philips screw holding another piece of trim to the left of the pedals, good place to run wire.
I grounded my amp with a stainless steel 1/4" #20 bolt with two washers. Between the headrests and the rear deck speakers are a number of holes and slots facing downwards. I just chose one easy to get to and put the nut and bolt through that. I didn't see great contact for ground, but once I tightened everything I read no resistance with my multimeter.
When you put your sub in, face it towards the latch (cones towards the latch) as far back as you can get it. It makes a world of difference. I noticed that my subs sounded much better with the trunk open. I googled about it and came up with http://www.installer.com/tech/aiming.html which is straight on. Only thing is, my trunk is now shot for doing anything with.
Going to Boston next week for a Pearl Jam show and my luggage is riding in the back seat
I'll put pics in my cardomain when I get a chance...nothing much to look at tho
Good luck,
G
