I would like more options, rather than making everything standard.Too many high-tech gadgets cause more maintenance costs.
I'll state this FACT one last time.
The more options available on a car, the more combinations of options there are for a given car. That leads to many different configurations of the same car being available. While that sounds good, it is not from a manufacturing standpoint. The more different configurations a car line has, the more it costs the manufacturer to build each car, and they pass that cost down to you, the buyer.
For example, a car with a manual window has a different door trim panel, different wiring, different interior door substructure, and a different window regulator than a car with power windows. If the manufacturer just makes power windows standard, they can buy a lot more switches and motors, which makes them less expensive per unit. Also, the cost savings is seen when they can order all one door panel, wiring harness, and window regulator. This cost saving is so advantageous to the manufacturer that they can actually put power windows on every car and charge you very little for it as compared to what the manual windows cost them to put on such a low number of units.
That was Honda's idea with Acura. Acuras are less expensive than Lexus and Infiniti models for a number of reasons, but the main one is that Acura makes cars 2 ways, with navigation and without. Everything else you could want is standard. By doing this and only offering 5 exterior colors and one or 2 interior colors with each exterior color, they reduce the number of different cars for any given model they make to 20 down from several hundred over at Lexus and Infiniti. That cost is passed directly down to you.
I welcome the opportunity to pay less for a better equipped car. Again, if you don't want a car with "toys" then buy another model that doesn't have them. No one is forcing you to buy a car with $100 keys or steering wheel controls. Like I said in my last post, if you want a Miata and don't want the "gadgets" buy a Solstice instead.
