Has anyone changed the thermostat on a 1ZZFE? It looks like I have to remove the alternator to access it. Any other ideas?
by Silver Bullet September 8, 2006
It is not too bad to get to - but you are correct, you do have to pull the alternator off to get at it.
I took mine off some time ago to check on something - basically:
- disconnect the negative battery terminal
- drain coolant (drain petcock on radiator - will take a while or pull the lower radiator hose if you are impatient).
- good idea to note the way the belt runs around the pulleys (take a pic or sketch it - usually there is a diagram of the routing under the hood, but sometimes it is too hard to read).
- get wrench on the belt tensioner and turn it to loosen the belt and pull belt off
- disconnect wire clip on alternator
- disconnect two leads on alternator
- loosen two bolts in the front of alternator and take alternator off
- should see the two nuts and ECT connection on the thermostat housing pretty clearly
- take connector lead off
- loosen two nuts and it should come off, if not tap it lightly with an end of the screwdriver or handle of a hammer and it should pop off.
- don't forget to check for the o-ring - sometimes it sticks to the housing, sometimes it will stick to the thermostat.
Thanks for the good info. It's unfortunate that Toyota decided to mix in a very domestic car design like this.
