I just installed drilled and slotted brake rotors and new pads. When I start braking above 45 or so mph, the brakes make a eerie "ghost" sound. ooooOOOOOoooo. When I hit 45 mph and descellerating, the ghost sound fades and disappears. Any ideas.
by twinky64, August 29, 2006
its normal. slotted rotors will howl or growl, drilled will make that sound you describle. its the way the gasses and air are being cut up across the surface of the rotor. i have to REALLY be braking hard to hear it. its sort of a grrrrr sound for me, but i hear it less since i tossed some scraps of sound deadner in my fender liners to quiet rain noise (which worked pretty well)
I didn't realize drilled rotors were noisy. How loud does it get??
Thank you very much bitterits normal. slotted rotors will howl or growl, drilled will make that sound you describle. its the way the gasses and air are being cut up across the surface of the rotor. i have to REALLY be braking hard to hear it. its sort of a grrrrr sound for me, but i hear it less since i tossed some scraps of sound deadner in my fender liners to quiet rain noise (which worked pretty well)
Just keep an eye on them from time to time. Unless they are oversized rotors or two piece deals, most of the OEM dimensioned rotors start to crack around the holes and slots. Nothing you really can do about that - just the OEM sized rotors have too little heat capacity. I found out the hard way several years ago with both slotted and drilled OEM sized rotors.
Just keep an eye on them from time to time. Unless they are oversized rotors or two piece deals, most of the OEM dimensioned rotors start to crack around the holes and slots. Nothing you really can do about that - just the OEM sized rotors have too little heat capacity. I found out the hard way several years ago with both slotted and drilled OEM sized rotors.Do they break apart or just cause excessive wear on the brake pads?
Just keep an eye on them from time to time. Unless they are oversized rotors or two piece deals, most of the OEM dimensioned rotors start to crack around the holes and slots. Nothing you really can do about that - just the OEM sized rotors have too little heat capacity. I found out the hard way several years ago with both slotted and drilled OEM sized rotors.But dont they have a higher heat capacity compared to the oem sized non drilled/slotted rotors? What does "two piece deals" mean?
In very severe cases, they will break apart - but that doesn't happen unless you drive like you were on a road course. Most of the successful slotted and drilled rotors utilize a "two-piece" rotor - hat design. Where the rotor is generally cast iron that is bolted to an aluminum hat to save weight. Some more exotic designs use carbon fiber or ceramic compounds for the rotor and a completely floating rotor - held on with pins to the aluminum hat. These are generally designed for fixed caliper applications - our sliding caliper would have to have a lot of work done to make anything useful.
The drilled and slotted rotors have LESS heat capacity than the plain rotor. The only thing that slotting does, is help with "cleaning" the pad as you are braking - does not really enhance any cooling, if anything it heats it up higher than a regular rotor. The drilled ones help reduce mass (equals less material = less heat capacity) and helps in wet weather/minor out gassing of pads. The guys who rave about these say how it helps with reducing the gases coming from the face of the pads (helps make better rotor to friction material contact). That might be the case a couple decades ago - but most new pad materials do not gas as much as the old compounds.
Drilling and slotting is not a bad idea - just have to increase the rotor size to offset the amount of material removed - otherwise it is mostly cosmetic in design.
the slots on my rotors arent that deep, however i think that when the brake pedal is down hard the slots do help the pad to bite into the rotor harder, but normal driving is no different, and im sure most of it is due to a better pad.
That is true - those slots do clean off the bottom of the pad, helping keep a fresh friction surface available for braking. Generally they recommend the higher performance pads in this case, since the slots also generate extra heat in the entire system. Most track use cars see slotted vs drilled, because the slots are generally shallow (most of the brake mass is still there) and the constant cleaning of the pads keeps them soft and more consistent in braking performance. Drawback is they tend to eat pads faster - a good trade IMO, I can replace the pads pretty easily, rather have brakes that respond the same way lap after lap.
Site with good info on brakes:
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
Some whitepapers and more detailed FAQs
http://www.stoptech.com/tech_info/tech_white_papers.shtml
Also, don't worry about the noises too much - as they wear in, the noise will start to go away and reduce quite a bit. If the noise gets louder as you drive around - then you have a problem and need to check both the pads and the rotors for possible damage. Hopefully these are at least Brembo blanks or better that were cut afterwards and repackaged. The OEM rotors are notoriously thin and drilling/slotted them would be an invitation to disaster.
yea, i went with hawk hps pads for the slotted rotors (i got powerslots which use brembo blanks). they do dust ALOT, but i dont really notice except on the highway. after a few hours of highway driving i'll stop to get gas and notice my alloy wheels look like gun metal! i dont mind changing pads a little more often if it means i stop a couple feet shorter.
fish, have you ever owned a 93-97 corolla with ABS? i like to call it the afterthought abs system since it only engages AFTER a wheel has locked. if im realy quick on and off the pedal i can lock a wheel and be off before the system can react. i actually like this since it lets me threshold brake to the maximium without abs tripping early, but i find it odd that the system would be designed like this. its the delco abs 4 i think, a 3 channel system.
No Corolla, but a Camry around those years with ABS and the Matix with ABS - I believe that is the way they are supposed to work. If you are fast enough on the brakes - you can actually cause the ABS to swithc ON/OFF before it has a chance to do anything. That's why they tell you to just stand on it and let the system work. Might also have something to do with the ABS computer - as the Matrix is lightening fast in response compared to the almost casual way the Camry worked. Not 100% sure if this is also a function of the Matrix's Electronic Brake-force Distribution (EBD) system or not. The Camry would lock its brakes for maybe a half-second (at least it felt that way) before the system kicked in. The Matrix is something like a 1/10 of second or quicker.
In very severe cases, they will break apart - but that doesn't happen unless you drive like you were on a road course. Most of the successful slotted and drilled rotors utilize a "two-piece" rotor - hat design. Where the rotor is generally cast iron that is bolted to an aluminum hat to save weight. Some more exotic designs use carbon fiber or ceramic compounds for the rotor and a completely floating rotor - held on with pins to the aluminum hat. These are generally designed for fixed caliper applications - our sliding caliper would have to have a lot of work done to make anything useful.What are the symptoms I would experience while driving if my rotors start to crack? What is the possiblilty that as soon as the crack occurs, it will instantaneously just sunder apart?The drilled and slotted rotors have LESS heat capacity than the plain rotor. The only thing that slotting does, is help with "cleaning" the pad as you are braking - does not really enhance any cooling, if anything it heats it up higher than a regular rotor. The drilled ones help reduce mass (equals less material = less heat capacity) and helps in wet weather/minor out gassing of pads. The guys who rave about these say how it helps with reducing the gases coming from the face of the pads (helps make better rotor to friction material contact). That might be the case a couple decades ago - but most new pad materials do not gas as much as the old compounds.
yea, i went with hawk hps pads for the slotted rotors (i got powerslots which use brembo blanks). they do dust ALOT, but i dont really notice except on the highway. after a few hours of highway driving i'll stop to get gas and notice my alloy wheels look like gun metal! i dont mind changing pads a little more often if it means i stop a couple feet shorter.the camry sounds like my corolla. about 1/2 second sounds right. the abs does work, just slowly...but im glad to have it!fish, have you ever owned a 93-97 corolla with ABS? i like to call it the afterthought abs system since it only engages AFTER a wheel has locked. if im realy quick on and off the pedal i can lock a wheel and be off before the system can react. i actually like this since it lets me threshold brake to the maximium without abs tripping early, but i find it odd that the system would be designed like this. its the delco abs 4 i think, a 3 channel system.
What are the symptoms I would experience while driving if my rotors start to crack? What is the possiblilty that as soon as the crack occurs, it will instantaneously just sunder apart?Just talked about in your other thread on drum brakes:
https://www.corolland.com/forums/index.php?...9477&st=15#
For the record - I have never personally gotton a rotor to blow up even under the most stress. The pulsing of the pedal and basically zero brakes will make you stop before you ever get to that point. But there was a televised one on a Corvette C5R some years ago that had its rotor blow apart at the end of a straight on the SpeedChannel network. Was not a pretty sight.
Yea, i know it was on two different threads. It just happened that both topics were covering the same topic. If that makes sense. One topic was mainly you replying and the other was mainly bitter. I wanted to get both of your opinionsJust talked about in your other thread on drum brakes:What are the symptoms I would experience while driving if my rotors start to crack? What is the possiblilty that as soon as the crack occurs, it will instantaneously just sunder apart?
Both threads illustrate that drilled rotors will crack and produce bad results.Yea, i know it was on two different threads. It just happened that both topics were covering the same topic. If that makes sense. One topic was mainly you replying and the other was mainly bitter. I wanted to get both of your opinionsJust talked about in your other thread on drum brakes:What are the symptoms I would experience while driving if my rotors start to crack? What is the possiblilty that as soon as the crack occurs, it will instantaneously just sunder apart?
quick run down, rotors wont make your car stop soon or make a stock pad bite hard, they only help by cooling better and help fight lose of break feel after reptiveted use, way to help your rotors from cracking, after using them alot, drive around slowly use breaks when needed, let them cool naturaly instead of a quick cool down, quick cool downs mean they will crack sooner
acutally slotted rotors can increase the bite of the pad, each slot wipes the pad surface clean so that the pads have less glaze on them. if you look at used pads from a car with slotted brakes you'll see that the pad surface is duller than those from a car with plain rotors.
ya a bit, not a whole lot though, if they are dirty with whatever the heat takes care of the old pad bite
yes, compound has alot to do with it, but the slots do help keep the pad surface cleaner and able to always bite with full force not to mention the advantage in the rain! if you get water between the pad (or on the pad itself) and rotor the slots help the steam to escape without floating the brake pad.
true true, i guess id just rather go to a bigger brake kit than slotted, sometimes its cheaper,
sometimes a BBK isnt always available. imho the best thing i did was get hawk HPS pads. btw, dual piston calipers from an ST185 celica DO fit the 7th gen corolla/2nd gen prizm. the caliper brackets bolt right on, i have a pair that i'll rebuild and paint over the winter and install in the spring for summertime.
heck ya good info on the st185, ehh big break kit is always avaible, buy bigger rotors with the match caliper and make your own braket for the caliper
making a caliper bracket is alot harder then just saying make one. the bracket has to stand up to some intense stresses, and do you know how much it costs to have one off pieces designed and produced?!? when it comes to brakes dont play around, do whats known to work or leave it alone.
