I have a 1998 Corolla with 150,000 miles on it that started with an intermittent check engine light this summer. All four injectors were replaced at that time. It seemed to run pretty well for a couple of months then started running very rough, missing on the way to the airport. Put a can or three of injector cleaner through it and it ran better but the check engine light is on constantly now. Codes are random misfire. One local garage couldn’t find anything just suggested a tune up. Put new plugs and wires on, may have helped a little. The coils check out ok on their resistance at least. Seems to be worse when the engine is cold and on acceleration. Conflicting reports as to the compression, Toyota when they put the injectors in, suggested the compression might be off some, but the local garage said the compression was fine.
