Guest HateMyToyota
When I hit the gas the car actually drops in RPM (250-500 RPM drop) before climbing. This problem occours in neutral as well as in drive and at any RPM range. If the car is at rest on any type of incline and I hit the throttle the RPM will drop to 500 and stay at 500 even with 100% throttle. The car will stay stationary or roll back. I can get it moving if I use the brake to build torque.
From 1250-4000 RPM the car feels normal as long as i keep my foot on the gas. Above 4000 RPM I have a serious loss in torque even at 100% throttle the car may shift 1500 RPM short of normal i think due to low torque.
I have changed the air filter and cleaned injectors. The check engine light is on and stays on, it just came on though and the problem has been going on for a while. The car has 36K and always maintained according to dealer specs.
Thanks to anyone who can help!!!
