Bud__Greene
93 corolla 7afe rebuild; starter won't turn over
Just got my motor back together after replacing the head gasket, rings and rod bearings.  I followed the Haynes manual first start procedure:  removed spark plugs, disconnected the fuel circuit opening relay, and removed the distributor cap and rotor and jumped the center contact to ground.  This is to prime the oil pump which was also replaced.  When I turn the key to "on," the radiator fan starts running and does not turn off without disconnecting the battery.   The check engine light, and the oil pressure warning light both come on.  The temperature gauge also moves into the bottom of the normal range.   When I turn the key to "start" nothing happens with the starter.  I removed the starter and had it tested.  It works.  I also tested the starter relay.  Powered, and unpowered it checks out.  The fusible links associated with the starter circuit both look good.  Any insight would be much appreciated.
Edited by Bud__Greene
Looks to me as though the coolant temperature sensor is disconnected, bad, or improperly grounded (or shorting). Check engine light would apply to that. Oil pressure light always goes on when you have the engine in Run but not running. Temp gauge is the giveaway. Fan runs because the car detects bad coolant temp sensor.
Code reader is your friend!!
