Busbig12
01 Corolla Le Jerks When Putting In Reverse
When I start my corolla when its cold and put it in reverse it does a slight jerk, after it warms up and than put it in reverse it does a big jerk that causes the whole car to jerk.
Also when i drive forward it does slight rough shifting. I flushed the tranny and put a new filter in and added an additive and still it does the same. Also it has 24,500 miles.
I know this may sound obvious, but did you actually check the fluid levels in the transmission? Check the manual for the procedure.
Did you really mean 24,500 miles on a 10 year old car?
i replace my shift cable, it runs from the throttle to the transmission.
my shift cable wasnt returning.
to replace to cable you need to drain the tranny and drop the pan.
inside you need to remove the cable.
