jfmtnbiker
Check Engine Light And New Computer
My wife currently owns a 2006 Toyota Corolla LE. This past week we were on our way to the shopping mall and suddenly the check engine light came on while driving down a hill. My first instinct was to take it to the dealer immediately...so that's what I did!
The trip to the dealer involved several traffic lights. This required me to accelerate from a complete stop. I noticed immediately that the transmission was not shifting correctly into second gear. This pattern seemed consistent with every traffic light the whole way to the dealer.
After leaving my vehicle at the dealer for a day, they determined that the computer is bad. The car has nearly 33,000 miles on it. They informed me that Toyota has an updated computer. Obviously, this is still a warranty issue.
I noticed in one of the previous forums that someone else experienced a similar issue. I am not really sure of the technical term for this computer, but I am told that the cost is approximately $600.00. The funny thing is that we just took this car on a long trip and it was fine. In fact, it gave us 38 mpg the entire trip!
My wife and I purchased the 100,000 mile platinum extended warranty at the time of sale. I am starting to feel like this was not a waste after this incident.
Any feedback from the corolla experts out there would be appreciated. Should this "computer" issue be a cause for alarm? Is this something many 2006 model year owners are experiencing?
I should add that my first thought after seeing the check engine light come on was that the fuel cap had a problem. About one month ago, the fuel cap needed to be replaced. This was not because it triggered the check engine light to illuminate, but because the clicking mechanism did not work. It was almost as if you could not get the gas cap to thread in completely.
The dealer replaced the gas cap without a problem! I though I would add this if it's any help. I am not a mechanic by any means. But, I can tell you my wife and I are a little concerned about this issue. We have heard nothing but excellent reviews regarding Toyota's Corolla.
I am not a 2006 Corolla owner, but I know that they do go bad and they are expensive.
It is one of those mysterious computer components that your car cannot run without.
Like anything electronic - they can work fine one moment and then fail on you without warning.
It is a good thing you have the warranty and you should take advantage of that to replace a bad computer.
Well, I just spoke with the dealer again yesterday. They informed me that this part is now on backorder. The earliest that I will see this part is the beginning of August. I just do not understand how a 2006 model Toyota Corolla can be down for such an extended period of time because of a part not being available. If I owned an older model Toyota, that would make sense.
Can anyone give me insight on this....?
Doesn't make sense to me either - you would think they stocked 2006 parts.
What if your car was unusable until the part came in - do they provide a loaner?
Does that mean you have to suffer with a bad part until then? Does not seem right.
Might mean that a large batch of the ECU computers were bad and are failing all over the place.
Your warranty should provide some rental coverage if dealer feels the transmission may be damaged by continuing to drive with malfunctioning shift points.
I am not able to drive my Corolla in this condition. It actually shifts horribly and the dealer advised that I do not use it until the part is replaced. They told me that using the vehicle in its current state my cause unnecessary mechanical wear to the transmission. So... it is out of commission until this part is received by the dealer.
I just do not understand. I mean, everyone tells me that Toyota's last and last and this is the first Toyota that my wife and I have ever owned. And, it's not like we didn't buy it new. Who knows?
Check your state lemon laws. I would drop your car off at the dealer and demand a loaner. Any mass produced car can have problems, but when they do come up, they should be taken care of. So far, we've had great luck and we are even getting our stereo replaced under warranty.
I don't know if mileage matters, but I don't think a car under warranty can be down for over a month.
I would really demand a loaner at the dealers cost. Let them keep your car at the dealer too. Don't take no for a answer. Leaving you high and dry like that is beyond wrong.
If the dealer does not want you to drive it, they should provide a loaner.
"My wife and I purchased the 100,000 mile platinum extended warranty at the time of sale. I am starting to feel like this was not a waste after this incident."
You have rental reimbursement. Contact the warranty administrator. They may be able to get your part expedited to save rental expense.
It is funny how fast parts can be found when someone else is paying for your inconvenience.
You all make excellent points. As far as the extended warranty is concerned, I am told that does not take effect until after the 36,000 miles warranty expires. Currently, I am still under the original factory warranty. The dealer is giving me a loaner.
I spoke with a Toyota representative three times since I initially called. They have been following up with my concern very well. As far as the part getting expedited, it is probably not going to happen.
Enjoy the loaner.
I can. OEM suppliers are only contracted to make a certain number of parts. The newer a car is the higher percentage of the parts that are made go to new car production and the fewer parts go to repair parts.
As a car ages the parts that are made become fewer in number but all of them are available as replacements, so they are more easily found.
The warranty should pay for any problems you are having, as well as a rental car since the dealer determined that the car is not driveable in its current condition. The warranty is one of the beautiful things about owning a new car.
Guest alsica
I have same issue with check engine light and rough shifting - at 34200 miles on my 06 corolla S check engine light came on and tramsmission started shifting hard - dealer told me they will keep the car while they wait for an new ECM - thie gave me a loaner( 2007 corolla for free) said it would be 2 or 3 weeks at least before ECM was in - they did mention that its actually coverd under the 8year/80000 emission warrantly - not sure why
