Dan{T.O.O}
Hello, I have a 2003 ce and want to replace the front struts. I can remove all the nuts(2 lower, brake hose bolt, 3 nuts on top). My problem is I can't remove the nut on the stabilizer bar. I can loosen it but it doesn't come off. I can ratchet it for as long as i want. It feels like the whole bolt is turning. The back of the bolt is a flat metal disk shape with a rubber padding that goes against the strut. When I start to loosen the nut I can see the bar separating from the strut and there is a little play but once I reach a certain point the nut just keep turning but doesn't come off. What am I doing wrong? Thanks.
